SD card hot swappable?
bottlecap
I would try, but coming from the Blackberry world you learn not to mess with technology. Is it possible to hot swap the SD card in the Eris?
This may not be recommended, but I did it just to see what happens...
I have taken mine out and put it back in while the phone was on, without doing any "mounting" or anything. When I put it back in, I was still able to to access my music and pictures without a restart.
I believe the problems arise when you have screen savers and information on the card (contact photos) that are not found when you put in a different card and access the programs that request the information.
The manual says to power down the phone before removing the SD card. In fact it specifies off, as opposed to just asleep. To my way of thinking, that says 'no' to a hot swap.
I think that's just to cover liability. Just like in Windows, you're supposed to do the "Remove USB" or whatever it is, before unplugging a USB drive. I also put this in and out without doing so, with no problems.
I personally believe that problems should only arise if you remove the card while data is actually being written. But I am always careful not to do that ;)
The problem would occur when you replaced the original card with a new one. You might have a bit of trouble accessing information that the phone doesn't know is there.
It is best to unmount the card and then mount the new one so that the phone knows there is new data to scan. Very easy to do. Settings > SD card & phone storage > Unmount SD card. Once the new card is in simply mount it and you are done.
Hmm, true, I did use the same card, no additional (or missing) data, and I did not do anything while the card was out... Good call! :D
