SD Card Immediately Mounts
CaptJimbo
All of the sudden when I connect my Droid to a computer, it immediately mounts the SD card. l don't get the option to mount. Not sure how to correct this so I get prompted to mount the SD card.
Thanks!
2.2 does this by default.
I know it's annoying. Is this the issue? I have doubletwist and I disabled that function.
Really? I'm using Bugless Beast Froyo and it doesn't do this. Are you sure it isn't another app?
Thanks all for responded.
Yes, it turns out it was DoubleTwist.
In my opinion, doing an auto mount of the SD card is not preferred. Where I work, plugging in removeable media places encryption software on the SD card. Since the card did an auto mount, the software got copied but fortunately does not appear to have had impact on my files. Hopefully, in 2.2 this will be optional setting.
So disable the option (or uninstall). Easy.
Same here. Running BB 0.2.1. Disabling the auto mount in DoubleTwist prevents this from happening.
