I was running skyraider 4.2 and everything was perfect. My brother in law convinced me to try nils gingersense. I made a nand first then flashed it. Everything worked fine except it nils gingersense ran slow and kind of choppy on my phone. I decided to go back to skyraider. I made another nand of nils gingersense first. I booted into recovery ran the nand and once it finished I immediately tried restoring my previous skyraider 4.3 nand which appeared to be successful. Once that finished I used the option to reboot in recovery. It started to reboot, showed my splash screen then just went to a black screen buzzed five times followed by the blinking green led. It did that every time I rebooted no matter what I tried. Finally I tried flashing the stock image and figured stock was better than a brick. This time different splash screen same result. I did some searching and found that if you plugged your phone in to the charger when the splash screen came on it would actually boot on. I tried this and was successful in getting the phone to turn on. Now the phone is back to stock and working but my SD card will not recognize on the phone (pulled it out and it works perfectly on my wife phone) and I also noticed that the 8 gb's of internal storage is also unrecognized by the phone. I am also unable to get into recovery. It shows a picture of a phone with like two green arrows making a circle and just sits there.
Any advice would be appreciated. I would like to be able to flash back to my previous skyraider nand but I would settle for a working SD card and internal memory. Thank you for any help in advance.
