Sd card issue
Most apps can't run from the SD card, and you won't get that option for those apps.
I had a lot of apps stored on my sd card I was having an issue with zedge app and I went to check thats when I noticed there was no option anymore on any of my apps to move them to the sd card
Well I installed a new sd card last night and noticed that on the origonal card there were no apps stored on it which is weird because I had almost of my downloaded apps on it
Is your sd card full?
I got a 125 gb sd card, started moving things from my phone to my new sd card then files started vanishing. Now my phone doesn't even see my card. Last time that happened my card was bad. Try useing another card, format it in your phone before you use it.
