SD Card Issue
  • Start date Start date
A
Android Question
Guest
Heyy, I hate to say this but i am desperate right now. I searched all over the internet for 2 hours for an answer and yet still no luck. All im trying to do is to install apps to my sd card(or move). I have a SAMSUNG GALAXY LEGEND i run 4.1.2 and i am with verizon. Just please someone help me.
as far as i know you have to be rooted and use an app like apps2sd i order to move apps to sd. you can try to search the play store for apps maybe they are non root apps to do so im not sure but worth a shot
There are apps which will install to SD without Your request. Sometimes You can force some persistant apps to install to SD by changing default install location (by adb command). The rest of apps will install in data/app folder and You need root to move to SD.
Hi
Yes, pretty certain that with 4.1.2 (which I have stuck with deliberately on my note 2 as I think its a largely trouble free version) you cant move apps to sd without rooting it.
Roger
But nowadays phones has big memory built-in so is it still the problem if some app don't want to move to SD? Galaxy ACE 3 has sth like 2,7GB.
