Help SD card issues
gutted
My SD card is being very finicky. Sometimes I get warnings about it being not present, or about it being blank, etc. Usually this happens when I have it plugged in via USB to my computer. Other times when not plugged in, when I start up the camera app it says there's no SD card present.
Now, I'm assuming it's the card itself... do you all think getting a new card would fix my issues? Is this common for our phone?
Try backing up your card reformatting it to fat32 and restoring the items back. let me know.
OFF-TOPIC
WOOT 500TH POST!
END OFF TOPIC
Thanks for the reply. I can't format with the Atrix since its stuck in the "preparing sd card, checking for errors" mode. How should I reformat? I did do fat32 when I used the PC but it was connected to the captivate. Also, how would I back it up, do I need a special app?
