Root SD card issues
illini4x4
Hi everyone. First off I have a rooted Ascend and I am running LauncherPro paid version and I have done the Icarus MOD.
I got a larger capacity microSD card from a friend. I copied all of my old data to a folder on my comp. I unmounted the SD card in my phone, took it out and put the new SD card in. Phone froze, so i took out the battery and restarted the phone. I formatted the new SD card in the phone and transferred all the data from my old SD card. Now I can not access any of my apps. The icons are all a general android icon and whenever I click on an app it says "Could not launch the requested activity". I tried putting back in my old card and nothing happened, so I formatted that one on my comp to Fat32, put back all the data on that card and then I got a damaged SD card message. I then put a brand new SD card in the phone and copied all the data to that one and I still have the problem with not being able to open apps. All the apps say they are installed when I go to the settings folder but i can not access them. Any advice would be much appreciated. Thanks!
I think I may have pinpointed what went wrong but I still do not know how to fix it. After I copied my data to the folder on my comp I wanted to add old pictures from an old back up to the card. This back up was from before I did the Icarus install. So like an idiot instead of just copying the picture folder to my SD folder on the comp, I copied ALL the data onto the SD folder. Once again not thinking I clicked on Yes to All when it asked to replace the folders with the same name. Since I did this would it have replaced all the needed folders to run Icarus with the folders from my pre-Icarus back up that was running Canvas?
If that was the case then I may be screwed because I basically replaced my Icarus data with my old data from when I had Canvas installed. Would reinstalling Icarus fix this problem? I don't care about reinstalling apps and what not, I just want to be able to use them lol Thanks!
Ok thank you! That's what I though may need to happen but was hoping there was a way around it. Thank God for saving contacts to Google! lol
For the reinstall would I need to uninstall first or just follow the directions on how to install it just as if I was doing it for the first time?
Also I noticed, that SuperUser is no longer in my app drawer and neither is z4root so will I need to completely start from scratch and d/l z4root first to get SuperUser privileges back and then go ahead with reinstalling Icarus? I checked my settings and I am still definitely running Icarus 1.0 now.
You probably had this issue because of apps2sd. Did you also back up and recreate your linux partition?
