SD Card needs cleared
AZ_Biker
Just rooted my TB, Thundershed 1.5, IMO 6.1 and noticed with vzn bloat removed all 70+ apps fit on internal memory. And with all the back ups, left over app data, etc, my 32gb SD card is down to 27gb. My question, how do I clear all the crap off the card without removing the rom b/u and other required stuff? I've moved all apps to phone. Any help is greatly appreciated. Thx.
Personally, I would leave it. But there are usually corresponding folders to go with software. If you connect your phone to your PC, you can back it up. If you whack something you needed you can put it back. I have a 32gb card and have 20 gb left. As long as I have a good amount of space, its cool - at least for me. You can also use titanium backup to backup your apps and data to your SD card. So if you flash again, you can restore back to where you were. Hope thus helps.
