Help SD card not reading
moconnor
1st, I'm new here to Droid and this is the 1st time I've tried to root a phone...
when I install the sd card and then under settings look for the available memory, the card is not showing up...is there something simple I'm overlooking?
The card is formated and shows up just fine with I plug it into my computer...
thanks in advance....
Mike
I'm having the same problem. Does anyone have a solution. I used to be able to read contents of the sd card on my phone, and it does not give the option to format the card.
