Beeblebrox
Hi,
was trying to installe Cyanogenmod and things went wrong
- I rooted my Galaxy S 2 "2.6.35.7-I9100JPKG2-CL342890" using "DooMLoRD_v3_ROOT-zergRush-busybox-su" Hurray!
- Backed up my apps and system files using Titanium Backup.
- I installed "ClockworkMod Recovery 4.0.1.4"
- downloaded the nightly file "cm_galaxys2_full-116.zip" and copied it to the external SD card. The card is a "Transcend Ultimate 16 GB microSDHC class 10. I plugged the card to my PC, copied the zip file and then back to the phone.
- Started the "Flashing CyanogenMod" process
- The Optional: Select backup and restore to create a backup of current installation on the Samsung Galaxy S II. should have been standard.... I unfortunately skipped this optional step. I did not even see it :\
- After "Wipe data/factory reset" and "Wipe cache partition", I could not install the CM since the SD card did not show
So now I have to wait to get a new card that may work better. I was not able to copy the file to the main memory since the phone will not boot and will not show when plugged to PC via USB to copy the file (gets detected but cannot access it via a file manager).
So my options seem like:
1) wait till stores open and buy a more common card
2) Use Odin to replace the ROM with "I9100JPKG2_Kernel"
3) Start Kies and plug to PC and hope it will prompt to restore/update firmware.
4) Get some miraculous solution from this nice forum like using Odin with CM mod (no idea if it is possible).
5) take the phone to some shop...
Any feedback is appreciated.
Thanks
Thanks
