First you are connecting the phone with a PC (not with CPU).
Second, after you connect the phone to PC, select Disk Drive option. Then use File Explorer on PC to find the SD card and browse its content.
You will see two new drive letters when you connect the phone and enable the "disk drive" option. One is the phone storage and the other is the SD card. Maybe you're looking at the wrong one.I have alot of music on my SD card, but when i plug the phone into the cpu and make it a disk drive, the music is no where to be found.....what needs to be done? The music is there because i play it on my phone.
^ This. As stated above, use a file manager to verify the specific location(s) of the files.You will see two new drive letters when you connect the phone and enable the "disk drive" option. One is the phone storage and the other is the SD card. Maybe you're looking at the wrong one.
