SD Card Partially Erased
Quizshow
Sometime in the last 30 minutes, most of the data on my sd card has disappeared. Camera photos, images, icons, videos etc are gone, but the music is ok. I have no idea what happened. The only thing I've done this morning is saved some snes roms to the sd card. Can anyone help me at all? :confused:
Have you hooked it up to your PC and checked?
If they aren't there, then I'm not sure
If they are there with it hooked to your PC, choose charge only and then try rebooting the phone.
Yeah, I checked via the pc and then rebooted. It's definitely missing all my photos. According to the the available space info, I'm missing about 1gb of stuff.
Hopefully, it's just a simple directory corruption - this can happen if the device is unplugged without unmounting (ejecting) it first, or it can happen just because.
First link explains the idea, the second may be the right tool for you. If you're on a Mac, let me know, I tend to assume folks use PCs around here.
How to Repair a Corrupt SD Card | eHow.com
FileRestorePlus - Easily undelete, unerase, and recover deleted files
Finally, a good discussion on this subject -
How to repair corrupted sd card? [Archive] - xda-developers
Hope this helps.
Is this a cheap 32gb memory card off of Ebay? A lot of those cards trick the system into thinking they're 32gb, but they're really 2gb or 4gb, and when you get to the point where you use up all the actual storage, the data remaining gets corrupted.
This is a 16gb class 2 that I bought from an amazon market seller (25.00). But the thought did cross my mind that I might have been scammed with a lower gb card. I've recovered what was lost and backed up everything so if stuff starts disappearing again, I know I've got a fishy card.
I had gotten really lazy about hitting that green arrow to remove hardware so lesson officially learned.
There you go.
Tell your friends that yanking out an SD card, USB drive, digital camera or music player - no matter how many times it went well for them - is just a game of Russian Roulette.
