Root sd card partitioning
hello there. i need help using apps2sd and partitioning. first of all i have had the sd card partitioned before to swap 96 mb, ext2 512 mb and the rest fat32. then today i ran wipe battery stats in amon ra recovery as i wanted to recalibrate. this also wiped my sd partitions i believe. now when i i re partition the sd card with the settings swap 0 mb ext2 256 mb and the rest fat32, it says succesful, but the phone will not allow to check apps2sd and when i look in the storage setting it sayd that there is to external partition. the total space shows the partition is there though as it has less than it should. please help. thank you very much
