Want to be able to move apps to my ext sd. Now you can move a few but most 3rd party apps and other things I would put on it , I can't. Really I want a root solution for the phone and then its all solved, but until then this is something that I wish I could do.Without root i don't think so mate.
What is it you're trying to do?
Yeah, that's what I really need, but so far no working root method I have found. I just thought maybe there was an app or work around to this.Android support for moving apps to sd cards left after Gingerbread and even then, as now with the few you've found, the entire app doesn't move.
So you have to root and install a hefty mod to what you want.
SD card permission fix isn't the issue.
