Help Sd card problem
raihan619
Guys help me out
Om using sgalaxy y. I recently upgraded from 2 gb to 8 gb- . I think its slow, it says's can't create new folder' from my phone- my files, then I downloaded sd tools and checked reading and writing speeds, its nearly 4mbps. Help me please is it the problem of my sd card? How can I speed up.my card and phone?
Guys help me out
can u pls tell what is your sd class:pcguru:
Guys help me out
try using SD speed increase app, it is available free in the google play. just set it to 2048 kb.
and if its still slow try reformatting ur sd card to fat32 using mini tool partition.
warning: formating sd card will delete all the data in it, so have a back up.
Thanks , but it aint working. and also it says 'parse error' eevery time i try to install downloaded APK's from phone(no problem with my 2gb)
i think theres another problem existing other than the sd card problem.
but try formatting ur sd card through pc.
Guys help me out
use sd booster application then the cache size 2048 , and use link2sd
additional check first your internal memory then dial *#9900# then choose copy to sd card it will add a bit mb in your internal memory..
