faugusztin
Member
Hi,
i'm having serious problems with the SD card on my Milestone. Let me explain :
1. If i try any generic app which tries to access the SD card, it says it's not there (Camera says "Please insert a SD card", other apps say similar warnings).
2. Settings>SD card & phone storage says Unavailable to everything, like if the card is not mounted.
3. Fun starts now - Ghost Commander has no problem reading and opening directories and files on the SD card.
4. if i connect the phone to computer via "Charge only" option, i have no problems to view the SD card contects via "adb shell", "ls /sdcard" commands. I also see the /sdcard line when i try to list the mounted partitions using the mount command.
Any ideas ?
Any ideas ?
