I bought a 64gb sd card for my phone over christmas. It works great with 1 exception. Everytime the phone is turned off/battery goes dead the phone restarts with a notification that the sd card is blank. Nothing from the card works and I have to reformat the card. Any help!!!
That depends. If it's a SanDisk card, contact SanDisk. They've modified their cards to get around a problem caused by Samsung, and they'll replace the card. Read SanDisk Ultra 64 GB microSDXC Class 10 UHS... fix it explains it all.
If it's not a SanDisk, you're out of luck, it's just a bad card. If you can't get it replaced by the place you bought it from you'll have to buy another one. (Do yourself a favor and buy a SanDisk this time.)
