SD Card Question
That's pushing your luck... :D
I remember once putting an SDHC card into a "non-SDHC" compatible device. Yet, it had no trouble managing the entire SD card.
Similarly, I've installed drives into machines that were a larger capacity than said machine could handle. The drives would work fine, but would be left mostly unused since the BIOS/drive controller/OS/all of the above couldn't address the entire drive. I assume the same would happen here.
Upvote 0
BEST TECH IN 2023
Smartphones
