Root SD card read only?
birthofahero
I just flashed to skyraider 2.5.2 and I am now getting a "SD card is mounted as read only" error. When I click on it in the notification bar it reloads the card and usually works after that but occasionally it will take several tries. This happens every time I reboot my phone. Skyraider issue? or something else...
My skyraider 2.5.2 works fine, I have never seen that error before. I would try a different SD card and see if you can get that error with a different card. If not then it might be your card.
