SD card reader for the note 10.1?
excav8ter
Is there an SD card reader for the Note 10.1 available? I have a POV cam that uses a regular SD card. It is supposed to stream videos via the WiFi that is built into the camera, but it's been a pain in the azz to get set up. So I am wondering if I can just buy an SD card reader that plugs into the accessory port on the bottom of the Note 10.1?
Thanks.
Thanks.
Yes you can find them on ebay. I would just get a usb otg cable and use a reader you already have since the usb otg can be used for a multitude of things
Going get one ordered up from Amazon tonight yet..... thank you.
Edit.....ordered from Amazon....should be here Thursday.
