android_ash
I have this same problem!!!!
I have the lg venis with boost mobile
With a 2gb sd card
Yesterday i got my phone wet put it in a zip lock bag of rice and left it there sknce 6am and took it out around 8pm it turned on i can make and get calls same with text i have small lines acrossed the screen which i can deal with and the power button gets kinda sticky but i can get it to work still. The down side is that now in my notification bar says sd card removed with the exclamation mark. When i open my gallery try taking pictures or even taking screen shots or saving pictures it says "sd card unmounted or not present" and the mount sd card option is grayed. the sd card is in correctly and works in an old phone of mine perfectly. I never had my phone plugged into any pc or usb port ive reset my phone regretfully. I took the battery out and sd card out and turned it off and on and still nothing. I want to know if theres any way i can fix this myself. Or is it done for?? I want to know before i spend any money on a new phone.
With a 2gb sd card
