Help SD card removed unexpectedly
Respected Sir,
1. As per i have already emailed you earlier 3times i have buy 2 mobiles galaxy y 1month ago.
2. in both mobiles i am getting error \microSD removed unexpectedly . as per your email support i gone to service center. thay have updated my software and told that error will now be removed. but still error remains very frequently.
3. then after i have remail you. so you have call me and told to go service center and talk to them. after that i gone to service center they told me that we will update your phone and problem will be solved.
4. they have updated. and told me that till 4 days from update dont insert memory card and when ever insert first format it.
5. after that i have exactly followed all the steps but problem not solved. and i found that proble, is not solved.
6. i think this is my life's major mistake that i have bought samsung mobile. samsung shows it supports 32GB but it even not running successfully with 2GB card that given by sumsung.
7. can company suggest me were to throw this mobile. its e-wase of india. previously i hope that samsung will support me. but after i reliase something different. each time company update and format my mobile so i have to everytime pay data charges of my required applications for download and for 4 days i have to wait for my mobile.
8. people why buy mobile for waiting and formatting?? with 3 times email and 2 visit of service center can not solve the problem of mobile. we are at government office we are not free for your service center visit. and email you. it is better to throw mobile.
thanking you for atleast reading my mail.
Respected Sir,
Samsung Kies has provided a new firmware update today for india, DDKK1, kernel version 2.6.35.7. Let us hope this will settle the issue of "SD card removed unexpectedly" I have updated to this firmware 3 hours ago, have not seen the SD card issue yet.
Hi,
Nimpravi...i think u r talking about baseband version S5360DDKJ2... right?
right now i have S5360DDKJ2.....how to get DDKK1...how to upgrade it?
my android version 2.3.6
kernel version 2.6.35.7 root@DELL144#1
I updated my firmware 2.3.6 with the fix 2.3.6 DXKK4 update release via kies and the SD card error is fix now. problem solve. ^_^
i upated my galaxy y 2.3.6 with new update, but it gives DDKK1 and not DDKK4 whats the difference?
SD card prob stll occurs sm time. pl reply?
Guys i bought the mobile yesterday,frm the very day it started to show this prob.. :( please guys help me to fix this issue
////the latest patch was able to fix this.////
i am frm India, could u tell me which version/update/patch i should go for to fix this issue ...
Also i dont know anything abt updating..any link (tutorials) available in net? we can do it ourself or shld go to service ctr?:confused:
Just back up all important files in your memorycard after that remove your memory card and if you have a memory card reader put your card there and plug to pc then reformat it to “FAT 32" this one solve my unexpectedly card remove.
Pls help me update
@mmiranoc
are you sure? this wil fix the auto sd card unmount problem? or we need to update the os version? +
if i copy all application which is installed in sd card to pc..after format the sd card if i paste once again in sd..app wil work or not?
yup thats true my same sd card problem is solved by s5360DDKK1
initially it was DDKj2 //
how to update it? any links? and guide lines plzz
I updated Galaxy Y couple of days back via kies to DDKL1 (India) firmware. And ever since I am getting boot loops! The phone gets restarted every few minutes. Does anyone know what the problem is and how to solve it?
hey i too had the same problem but it is solved now...
process...
first tell the samsung service man to formate ur mobile with root format....(they uses some numbers to formate the mobile and then remove ur sim card and memory card and give that to samsung service man for updation....they will 1st formate ur total android mobile and then tey will install 2.3.6.
this problem is now solved..
this problem occurs,,,
because..
1.updating mobile while memory card is in sim.......
thats the problem....
so dont update firmware urself.........
its free of cost....
samsung service people wil do it... thanks!
me too having same problem bro!!!with the same phone!
for all whom having memory card removed unexpectedly issue go for a new branded memory card either transend or sand disk u wont get that problem again definetly. i have done that now i m not having that issue my friends also tried no issues thereafter... the card that comes with the mobile box is not a good one its very worst...so change ur memory card:):):)
hey guys, i got the same problem which was solved by replacing micro sd with new one.before replacing i used to get error message when phone is in idle mode for 5-10 min.I took to customer care for 3-4 times, later found that it is micro sd problem!!Thnx to aariff :)
