Help sd card removed
iamnana
I have optimus m (metro) i got message sd card has been removed, tried turn on and off, tried removing sd and putting back, whats up, I got a lot of prescious pix on there and my camera doesnt work:(
This happened to me the other day and I posted a fix on my twitter. If you have a multi reader insert the micro sd into your computer and in windows command prompt type chkdsk /x /f x:
X: being the drive letter your sd card is.
Example on my PC it shows up as F: so I type chkdsk /x /f F:
this also happened to me, but it was the little pins that were to blame. one was recessed and then broke off. card couldn't be read. got another optimus from a friend and it was a rebooting one. I took a look at the slot and bent the broken pin up to make a connection.
not saying thats your case, but I would do what above said and connect it to your computer and see if it shows up. windows may notice the error and prompt to repair, if not, do a chkdsk.
