Can I replace my micro SD with basically any Micro SD Card? I got one that says:
"l Compliant with the SD Specification Version 2.00.
l Versatile when combined with the adapter, can be used as a full-size
standard SDHC or MiniSD card with adapters(not included).
l Compatible with microSDHC host devices; not compatible with standard microSD-enabled device/readers.
l File System Format: FAT 32.
l Operating temperatures: -13 F to 185 F (-25 C to 85 C).
l Storage temperatures" -40 F to 185 F (-40 C to 85 C).
l Weight: 24 g
l Size: approx 15.5*10*1 mm"
Will it work? THANKS!
l Weight: 24 g
