Help SD card vs Internal
I installed an SD card but it appears all my pics and music are being stored on the internal memory. What do I need to do to fix this problem?
Thanks for your help
when you connect the HTC to the computer you will see the sd card and the internal memory. just drop and drag your files to the SD card instead of the internal memory.
For the pictures you take with the phone it defaults to using the internal storage, but can be changed.
If you go into the camera app, press Menu, then go to Settings (looks like gears) there is an option there for 'Storage' which can be set to 'Storage Card' or 'Phone Storage'.
