superhoops
Hi
I bought a 64gb memory card to get my music onto the note. However without fail after about 2 minutes of copying (by drag and drop) I get a message "The device has either stopped responding or has been disconnected". Dismounting and then mounting the card and unplugging the usb brings it back for a few minutes before the same thing happens.
The songs that have copied are playing ok on the note but if I open up a music folder from the memory card on the pc it is empty, and yet they play on the device.
I have formatted the card, tried copying the music files with the card in my S3(same results) and am at a loss what to do. Is it likely the card is faulty or is it a problem with my pc or even with both my S3 and Note.
I would appreciate any advice. Thanks all
