Root SD card wont mount in recovery
coled91
I have been having problems getting the SD card to mount in recovery lately. I have both SPrecovery and clockworld flashed and i have tried reflashing them as that usually works. Nothing is working though.. It is the 16gb card that I got with my replacement Droid. I have never had this problem before. Any suggestions?
I just went through this and the only thing that worked for me was using a different sd card. Hopefully you can figure something else out.
ok do this
#1 Go to rom manager
#2 Click menu go to settings
#3 Check erase recovery
#4 Hit back then click menu
#5 then click clear download cache
Then do the normal flash and try and do it then
it worked for me
