Root SD card won't mount
innate024
Member
I just got a new 16gb class 10 sdcard yesterday. I formatted it, partitioned it w/ killertonez a2sd, and flashed Velocity .3 with Turbo4 and OC kernel. When my phone reboots, I get a notification that reads "SD card removed" and it will not load my ROM or anything. I can manually re-insert the card, but none of my data will load; and every time I reboot or power cycle my phone, I get the same error message.
I didn't do anything out of the ordinary and I've wiped/reflashed a few times now. I know I am doing it correctly - is this just a card or phone issue? Is there a script to permanently mount the card?
Any insights would be greatly appreciated!!
EDIT: The last few times I have rebooted, I get the "SD card removed" notification and then it will mount like a minute later; but still won't load my data on boot.
Class 10?? Holy crap, that's fast. It shouldn't cause problems as far as I know, but I doubt the phone can ever write that fast---likely class 10 was overkill.
I assume by wiped/reflashed several times you mean the ROM. Have you tried re-wiping and partitioning the card?
Yes, I re-wiped and partioned the card - but I got the same error message. Every time I reflashed the ROM I would do a clean wipe (data, cache, dalvik, sd-ext), and start from scratch. I made a few backups, but they were useless since my sdcard would not mount when the phone rebooted.
The card is corrupted. My computer will no longer read it so I cannot re-format it anymore. I am going to return/exchange it. Do you really think class 10 was overkill?
I ended up using my old 8gb, class 4 card and got rid of a lot of some music and pics to make more space. It will do until I get my replacement.
I appreciate your input, though.
Yeah, I agree with darkxsun that class 10 was overkill.
I highly doubt that a phone would even be able to write that fast. The main benefit between a class 6 and a class 10 is noticed when recording full HD video and shooting hi-res photos at a rapid frames per second rate.
