berocksr
Member
I'm having a slight problem and need some advice with reinstalling apps and my games from SD card. I have recently done the EXT4 wipe and installed leedriod 3.3. Before I used my SD card as a gold card I copied the contents to my pc. Then formated the SD card and put the contents back on there. Assuming it would all be fine. Google did reinstall some of my apps but not others. I always choose option to move to sd card with new games and apps I install as I don't want to use my phones memory. Today I did a ROM backup using Rom manager and I noticed that there where files in my SD card under the android secure folder, some of which Google didn't recover. Does this mean the games are still there and I can get them back somehow? Or if not how do I delete them do they are not using space on my sd card for something I'm not even using ???
