on the computer? If so i had that problem to, might want to reinstall your comps drivers for lg. Should be able to find them under the device manager, if your using pc. Then just go download the drivers from lg site.
Are you trying to get your phone or computer to recognize your SD Card?
If its your computer how big is the SD card? Are you doing it through usb while mounted on the phone or an SD card reader on the computer? Alot of your lower end SD card readers can only read SD cards of 8GB 16GB etc. So make sure the SD card isnt larger than what it can read?
go to the lg.com website click on mobile phones link on the left find the optimus m which im assuming you have then when the screen pops up with the phone it should say "app-solutely simple" click on resources and you can download the driver needed right there hope this helps
