SD Card
wilkie67
I am downloading photos from skydrive and it says that it's downloaded to the skydrive folder on my SD Card. I would like to use the photos to use on my contact list . Is there any way I can access this folder without going through the computer
Thanks for that, I can't see the folder and I'm just a simpleton and never used a file manager before can you help me out on this?
I don't use Skydrive. But the Google Playstore has some utilities to help you manage your Skydrive. Maybe you should check them out...
