Can I insert the card from my sway and will all the pics etc be there on the Incredible? Where is the slot? I don't see it in the little book vz sent. tia
Pat
As long as your card is a microSD it should work just fine in the Incredible. If you have pictures saved on it, I would pull them off before putting it in. Then format the card in the device and copy your pictures back.
Here's a thread where you can download the User Guide for your phone:
Pat
i think they didnt ship box with the manual because its so large. go to the link below and scroll down, there are PDF files with the full manual; its over 10MB!!
the slot is under the case, you have to remove the back and pull the battery, then there is a little slot right on the side of the phone. i THINK it will see all your old stuff from the other phone; someone correct me if i am wrong please...
