hstein Newbie Apr 4, 2013 #1 I just got a SD Card for my Avid. I want games etc, to download to the SD Card, and not the internal drive. How do I accomplish that? Thanks.
D Deleted User Guest Apr 4, 2013 #2 hstein said: I just got a SD Card for my Avid. I want games etc, to download to the SD Card, and not the internal drive. How do I accomplish that? Thanks. Click to expand... If your talking about runnin them from sd then after install move to sd in app management. If your talkin bout the actual dl that comes from the Play Store going to the sd then I'm pretty sure you'll need to be rooted
hstein Newbie Apr 4, 2013 #3 totlth said: If your talking about runnin them from sd then after install move to sd in app management. If your talkin bout the actual dl that comes from the Play Store going to the sd then I'm pretty sure you'll need to be rooted Click to expand... Yeah, I meant dl from play store. So, then I can download to internal drive and then move to sd in app management. Correct?
D Deleted User Guest Apr 4, 2013 #4 hstein said: Yeah, I meant dl from play store. So, then I can download to internal drive and then move to sd in app management. Correct? Click to expand... Yes the app you can move to sd in system settings.
