Help SD card
Slick
"SD card is blank or has an unsupported file system" is displayed in my notifications bar. I just bought a 16 gigabyte SD card and its doing this. Any suggestions?
Did you format it?
System settings> storage> format
If that doesn't work then you might have gotten a bunk sd card and you should return or exchange it
I hope you didn't get this sd card from ebay.:eek::D if not what kind of sd did you get . Was it a class 10
I think it was a class ten. But I did buy it from ebay. Here is a picture.
Sorry to hear that. It's not unusual. That happens from time to time. I think you should return or exchange it.
I'm using a Samsung brand class 10 16GB w/OOTB Reverb JB 4.1.2 and works great. I didn't even have to format it.
So its just a bad SD card and it is supported by my phone?
Yes its possible but do you have another phone to or device to try it in maybe a camera . Try it out they are good cards for hd games and more cause the mb it moves fast .
O wow i had a ebay item just like this a 64 gigabytes sd card . Black in color .but its funny that how i get to 4 mb :eek: yes 4mb the card would erase everything . Didn't know til i tried it in my camera take a photo seen a warning . Turns out it was only a 2gb sold on ebay as a 64gb . But since you just got it send it back get your money back .i think best buy or tigerdirect selling the same cards on sale 59.00 or 75.00 .
AND FOR THE FUTURE BUYS FROM EBAY . TRY NOT TO GET SD CARDS .
Yep, buy the seller. I got mine from eBay btw. No problem. That being said, reputable online vendors like MicroCenter.com or Newegg would be always a safe bet.
