Help SD card
SanDisk is the best brand for any device. There are two manufacturers of the chips that go into the cards, a joint SanDisk/Toshiba plant (that produces SanDisk cards) and Samsung. SanDisk is a much easier firm to work with if you ever have a problem, and the price is about the same. (If you pay a few dollars more than you would for a Samsung card, it's worth the peace of mind.)
SanDisk isn't much more (if at all) more expensive than the same card in a Samsung. Samsung makes good chips. But if you ever have a problem, they're much more difficult to deal with than SanDisk is.
If you buy anyone else's card? Who knows what you're buying? A 64GB memory chip with loads of bad cells, with the card programmed to say it's 32GB? (And the card will keep failing, until part of that 32GB fails - probably right after the warranty runs out.) Or you can buy a "64GB Class 10" microSD card with adapter from a company listing on eBay, shipping from the US, for $12 including free 5 day shipping to the US (and it includes a card reader, which normally sells for a couple of bucks). Is it really Class 10? Is it really 64GB?
You can even get a "128GB, Class 10" card for $20.50 including shipping.
(And the guy in the alley will sell you a "genoo-wine Rolecks" for $25 too.)
As long as I keep my SD card backed up (and I do - to both Google Drive and Dropbox), if it's a SanDisk card I don't care if it fails. I'll be without a card for a few days.
What SD file systems does the S5 understand? 128 Gb means exFAT. If the S5 is listed as taking 128 Gb, is there an alternative file system I'm missing?
I purchased a sandisk card today.
It fixed some problems I was having downloading apps.
The bad one I took out was a samsung card.
The problem it had was intermittent. When I checked sd card memory one time it would give me stats then other times it would say there was no sd card.
