Was wondering if anyone knew how to test an SD card,,, I think mine is going bad it keeps unexpectingly removing itself so I have to reboot in order for it to except my SD card,,,,,,,, thank you for any and all help and info.........
Hi patsfann,
You can test the SD card with various different PC software programs and check the read/write speeds and the blocks/sectors of the SD card and perform an integrity check and report if there are any bad sectors or blocks.
There are even some apps that will test SD cards too.
Obviously to test on a PC you need a SD card reader. Read the directions, some PC software needs a clean and fresh formatted SD card to get a highly accurate reading and some may even delete the data on the SD card. So you need to careful there.
Hopefully that will get you started in the right direction and Hopefully its not a hardware/software issue with the device.
