Hi, I'm new here and at a loss. Please help me, Im going to have a breakdown! Apologies for the length of this but best you know full issue.
I rooted my phone today using these instructions - YouTube - TheGadgetsReviews's Channel
Essentially, I turned on debugging, installed all relevant drivers (PC and phone), installed and launched unrevoked 3 (rooted fine), installed ROM Manager and made backup (tried Titanium but it said I needed something I didnt have), then I installed the Cyanogen 7 ROM (using their own instructions). As I said, I made a backup. The rooting was fine and Cyanogen installed and ran successfully (and looked great might I add).
However, none of my contacts, data nor my apps had moved over onto the new ROM. I understand that this is becasue my phone essentially wiped itself and made a clean install (I should have opted for an update not a clean instal but I didnt know that!). Anyway, in hope of rectifying this, I opened up ROM Manager and tried to load the recovery/back up file. Phone turned off and then tried to "revert" itself (little pic of box with files coming out). It said the process was complete. Phone turned off once again and tried to start up. It returned to my original O2 welcome screen and that is as far as it went and that happens everytime I start my phone.
So I tried using EBOOT and flashing recovery from there (holding down power and volume -). I can get to the black and green recovery screen (ClockworkMod v2.5.0.7) but when I try to flash the recovery, the phone loads up the blue O2 screen and freezes. I have tried to run the .zip file on the SD card but it doesnt do anything and just loads up the recovery menu again. I can see the back up image in the restore menu but when I click it, again I see a small box with data coming out and the process completes but I get this message at the end "sd-ext.img not found. Skipping restore of /sd-ext.img". When I then select "reboot system now" the same thing happens, blue screen freeze.
Please please please help me. I backed it up so that I dont have this problem but I cant even get to my back up! Any advice please.
Bravo PUT 1 SHIP S-ON
HBOOT 0.93.0001
MICROP-031d
TOUCHPANEL - SYNW0101
RADIO - 5.11.05.27
Many thanks in advance
HBOOT 0.93.0001
MICROP-031d
RADIO - 5.11.05.27
