SD/SDHC capacity
elgibby
Member
I'm just about to pull the trigger on a Vibrant but have come across an inconsistency. Reviews have said the Vibrant will accept up to a 32gig SD card; but the manual I'm plowing through says capacity is 16. If 16 is the limit, it could be a deal killer for me.
Is it 16 or 32?
thx!
The phone comes with 16GB of internal memory, with the addition of an SD card slot. It also comes with a 2GB SD card (which has Avatar preloaded onto it), but you could replace the 2GB card with a 32GB card, taking your total storage space to 48GB.
