sdCard damaged
ovigt71
hello. before to open a new tread, i was searching on this forum and also on google for some similar situation and I still have doubt. Is this custom rom so instable then after some time I can't access my sdCard? Have I done something wrong, i mean the installation procedure and rooting? Do I installed a correct custom rom? My sdCard is really bad brand, but I already replaced with a new one, and I have similar situation.... Is showing sdCard Damaged and is asking for formating. Of course, after formating, everything since to be ok, but after a while, the situation is coming over and over again. I already lost a hell of data, music, and other stuff. Can somebody explain to me why and can I avoid this? Before rooting everything was OK..... I don't wanna blame the rom, maybe my handset is with problems..... so? thanks in advance for answers....if any....;)
Which custom ROM? Which installation procedure did you follow? Did you repartition your card, and if so how?
If everything was okay prior to the update then my suggestion is to roll back to a pre-root Nandroid backup and, once you've verified that the SD card is working, start again from the beginning.
Modaco costom rom 2.8. Core Chinese this is my rom. The original was 2.73.721.9 1467 CL#62020. Shall I roll back?
