Hi all, I took the sdcard from my Droid x and put it in my bionic. Now I have two SD card entries, one is SD card and the other is SD card-ext. Can I transfer the items from the SD card ext to the SD card and delete the ext all together?
Thanks, Scott.
Assuming your Bionic is anything like my Galaxy S2, sdcard refers to internal storage while SD card ext refers to the actual SD card. So I wouldn't remove it.
Thanks, Scott.
What they said is true, but you also need to know this:
most Android apps are hardcoded to use sdcard for data storage - so, yeah, all your app data that you had stored on your old phone to the sdcard will, in fact, probably need to be moved to the sdcard on the BIONIC.
So, I just got this phone yesterday from the droidX and noticed this also, actually it wasn't till I tried to upload my backups from the card to note everything. I was confused half the night, and I don't think all my apps on the card were showing up on the droid at first. Now they I learned this is the external vs. internal do I cut and paste the app files that are on the ext card to internal? Or do I delete the folders if I make sure they are empty? What if I move the apps that I downloaded to the bionic to save to ext-card? would they merge together then?
