Hi, I have removed my 8GB sdcard from my old nokia xpressmusic 5800 and i have pluged it into my new samsung galaxy s2 phone, but when i go into the storage options, formatting/inserting possibilities are disabled for the sdcard section..
Hello and welcome to Android Forum motoko00.
You cannot expect a memory card that is formatted and set up for a Nokia symbian handset to automatically work in an Android one.
Your best bet is to tranfer all you files from the SDcard to your PC. Then place the card in your Android phone and go to...
Settings > Storage > Format SD card... and format the card.
Now you can copy your stuff back to the SD card and reboot your phone and all should be good.
Hope this helps.![]()
When you formatted your card in Windows did you use NTFS or FAT32?
What brand is the microsd card? did you buy it from ebay?
Have you check that it is not a fake, see link below for a tester
h2testw
