anbageorge
My Rezound came with a 16gb class 4 microSD card. I'm wondering what the fastest speed the device can write to the card is. Will upgrading to a class 6 or class 10 microSD card make reading data faster?
I read in another forum that a guy has a class 10 card in the Rezound. Your mileage may vary. I don't know if the Rezound hardware can write as fast as the card will allow though.
I have a PNY 32GB Class 10 and have noticed a huge improvement over the class 4 that came with this phone. When transferring files via USB, the write speed seems to fluctuate between 8Gb /s and 10.5 Gb /s. The class 4 that came with this phone would register between 2Gb /s and 3.5 Gb /s.
I know that transferring via USB will be faster with a higher class, but I'm wondering about the phone's read/write speed. I'd like to upgrade my sdcard, but I don't want to waste money on a higher class if it's not going to improve performance.
Amazon has some good deals on 32 gb microSD cards class 6:
Komputerbay 32GB MicroSD SDHC Microsdhc Class 6 with Micro SD Adapter and USB Reader - $40
I tried searching to find the phone's data access speed to sdcards, but couldn't find any info.
Does anybody have personal experience with increasing the class on the sdcard and noticing improved performance? Does it improve performance for apps which are on the sdcard? What about other scenarios?
How can it transfer even 1 mb/s since usb 2.0 is only rated at 480 mb/s?
Not sure I follow your question. USB 2.0 maxes out at 480 Mbits/s, or 60 Mbytes/s (8 bits = 1 byte). Why would it not be able to transfer 1Mbyte/s, or 1/60th of its maximum rated speed?
maybe he meant 1 gb/s since i believe some did state they were transferring that fast??
This was the quote I was referring to.
I don't know how fast the phone can read/write to a card or even to the internal memory for that matter.
Previous post fixed. Thanks!You are right. Several nights with little sleep will kill my multitasking ability. I meant Mb/s, not Gb/s.Previous post fixed. Thanks!
thanks!
I was confused and excited! I wanted some gb/s speeds!![]()
Just want to clear up some misconceptions: Speed class ratings specify minimum write speeds supported by a card, but don't say anything about read speeds. It's easily possible that a good quality Class 2 card would have faster reads than a marginal Class 6 card. It's also possible that the Rezound's microSD interface can't keep up with the very fastest (and most expensive) cards available. More info here.
Wow, that card got some bad reviews. I bought one before reading the reviews (silly me) so we'll see.Here's a Class 10 32 GB SD card at Newegg for $40.00 shipped.
Newegg.com - Wintec 32GB Micro SDHC FileMate Mobile Professional SDHC Model 3FMUSD32GBC10-R
I don't question your experience, just pointing out that read performance depend on the particular brand and model of the SD card, not on its speed class (which only guarantees write performance). Your new Class 10 card may read a lot faster than your old Class 4 card, but some other high end Class 6 card might be even faster.
