search feature not working
lakebound
I cannot search the forums for answers to questions I may have. I can post question but if I am looking for info it just keeps loading and never stops. Anyone know why?
Welcome to the Android Forums!
I'm not aware of any issues with search. If the problem continues go to the Suggestion box & feedback forum and post a thread there asking about it.
Suggestion Box & Feedback - Android Forums
Our forum administrator, Phases, will see it and check into it for you.
Another way to search Android Forums is to go to Google.com. In the search bar enter site:androidforums.com and the search criteria you want to use. Google will then search it's spidered archive of Android Forums for the search criteria that you specified.
YesWebpage error detailsUser Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)Timestamp: Thu, 19 May 2011 12:31:18 UTCMessage: Syntax errorLine: 1Char: 1Code: 0URI: http://ad4.netshelter.net/adj/ns.ph...t=ist;sz=728x90;ord=6147525984660267?Message: Expected identifier, string or numberLine: 9Char: 2Code: 0URI: http://phandroid.com/js/g-api-search.js?rnd=931674Message: Syntax errorLine: 1Char: 1Code: 0URI: http://adv.netshelter.net/context_k.../search/?ref=af&q=test&t=Android Search&d=&k=
