Help Secured Folder
You could try encrypring the files with TS 2 although I am not sure if this only works with pictures and videos or not. Since there are so many different ways of accessing the folder encryption is probably the only way to go.
Hope this helps...
Regards,
Eric Ritchie.
If you are trying to secure apps you might try Perfect App Lock. I'm not sure but this may also allow you to secure folders.
I've tried it,, it works but does not hide the icon,, I want to hide the app icon as well,, thanks
Hope this helps...
Regards,
Eric Ritchie.
would it hide the icons ?
