Help Seems to reset some settings over night
noz81
Noticed an issue that some settings seem to reset over night. i go to bed with phone in vibrate mode and wake up and its back on its normal setting?! not great when it ringtone starts going at work when i think its in vibrate mode! Also had the same thing with Advanced Task Killer, its running at night, then dissappeard in the morning. any ideas??
i wonder if its the task killer causing the issues with the sound profile. Sorry, i'm fairly new to Android, what are the downsides of task killers? On another subject, is there any way to make the browser start at my home page rather than the page i was was on last, dont see the point in having a home page set up if it always just opens at the last page i was on...
Cheers
Cheers
Android Task Killers Explained: What They Do and Why You Shouldn't Use Them is quite a good article.
Yes, that is a bit annoying about the browser, I kind of got round it by having a shortcut to the bookmark of my choice rather than a shortcut to the browser in my dock.
