wake69
Android Expert
I have received a Seidio Convert case for my 3VO to review.
What is in the box:
Hard plastic inner case
Rubber outside
Hard plastic clip
Holster
1 Screen protector
Initial thoughts:
The screen protector given is their ultimate screen guard. basically a static screen protector. I an not good at applying these, i always get bubbles that will not come out. Would have thought that Seidio would have gone the way of other case makers and would have included screen protector as part of the case and not an add on.
Instillation:
Very easy, similar to the convert case i had for the OG EVO (HAHA). Slide on hard inner case, put on rubber outer case, apply outer plastic clip, and you are done.
Holster:
Fits face in only. Lock on clip to keep phone in holster. Belt clip swivels for multiple options to wear.
Camera Protection:
As with the EVO case, there is a flap to cover the camera. This time, there is a tab at the top to pull out the flap. However with sausage fingers like mine, still a little difficult. Also, the flap stays down on the back of the case better than with the EVO, so there are improvements.
Thoughts so far:
Not a fan of the screen protector, however, 3d is very watchable with this screen protector, almost a little easier to view.
Rubber case is not slick and stays place when putting in and pulling out of pocket. Camera cover and charging cover are relatively easy to use. 3d switch, camera button, power button and volume rocker are easy to use.
More to follow with use over the weekend.
Initial rating 7.5/10
What is in the box:
Rubber outside
Hard plastic clip
Holster
1 Screen protector
Initial thoughts:
Instillation:
Holster:
Camera Protection:
Thoughts so far:
The case did not block any ports/buttons, and I still found all of the buttons easy to press. If I had to nitpick, it blocks part of the 2D/3D label on the phone, but you can still kinda read it. This would make a nice slim case to carry in the pocket. Although one concern I do have that I did not get to test is whether this makes the phone significantly hotter due to the felt like material on the inside of the case.
