firemedic1343
Member
Please post your thoughts, I'll start.
I received my Seidio Innocase Rugged Case and Holster for my EVO 4G. It consists of a Innocase II Surface, a soft plastic shell that wraps around the Innocase II Surface. The third and final piece is an exoskeleton that fits around the soft plastic shell. There is also a nicely built holster that has a nice locking button.
Fit- The fit is excellent, everything slips on tight but not too tight. Be careful not to pull off your screen protector when putting this case on your EVO.
Materials- The materials seem like they are tough and durable. The problem is that the soft plastic is very thin in the areas where the exoskeleton fits on it.
Durability- This solid feeling case should outlast my EVO in my opinion.
Protection- I doubt that this case provides more protection than the Active cases. I would like a thicker soft layer like the Active cases have. However, this rugged case does come with a sturdy clip and protection of ports and camera lens. The Surface case that the rugged fits around is also a plus for anyone that has need for a sleeker looking case at times.
Overall, I think I would be happier with an Otterbox type design, I think they are tougher. But the Rugged and Active are both available now. I would recommend the Innocase Active over the Rugged if you have no need for an included clip, camera lens protection and want to save some cash.
*The rugged case comes with a screen protector, which some have liked, I personally prefer something tougher.
This is my very subjective opinion, I'm sure I missed a few things. Please share your opinions as well!
