Accessories Seido Innocase II Cace pre-order.
Will the Innocase work with the extended life 3500 mAh battery which adds 3-4mm to the phone?
You will have to buy a different Innocase that works with the thicker battery. The holster will still work as the device faces into the holster, however, the Innocase is made as a tight fight for the current device with the standard battery door. They will most assuredly have something available for it when the 3500 is released.
I had one with my Storm and loved it. Just ordered mine and waiting for it to ship next week!
Are these worth the price? How well do they protect the phone?
It's not just the protection; the holster by far has the best clip on/off action I have seen
REGARDING EARLY UNIT PROBLEMS....
I have had these on my Curve, Storm, and Moto Droid, so this is my 4th ( I must be satisfied then).
Had slight problem with the one for my Droid, they re-worked some things and send me a replacement part a couple weeks later
Man i wish we could get a mockup of what otterbox has in store for the incredible, im really tempted to snag one of these but loved the otterbox for my storm 2
Thank you all for your comments! For the Innocell 3500mAh Extended Battery, you would need to have a separate Innocase Extended because it changes the dimensions of the phone.
Regardless of this or the Innocase Extended, they remain to be very pocketable. Even with the Innocell.
What is your ETA on the 3500 mAh Innocell?
What about the Innocase Extended?
I think if you gave us rough dates, we would feel more comfortable in forgoing other options.
REQUEST: Please offer the Innocase II in burgundy or a deep orange!
Did the extra thickness bother you? I'm wondering if the 3-4mm will matter or if I should just get that because the phone will last waaay longer and be more convenient. I do love thin tho...
It did initially because it changed the feel of the phone slightly, but not overly much. After a few days, I changed the battery out to test something that was going on with the phone, and it didn't feel right without having that extra weight/thickness there, so I had already become acclimated to it! ;)
You'll be fine with it. Much like the phone felt different in your hands when you got this phone (from what you had before it), the same will happen with the 3500. However, it won't take long at all to get used to it.
SEIDIO,
do you think the holster designed for use with the Innocase will also fit around the Verizon silicone case?
I'd also like to see clear and red (and black like the VZW gradient would be awesome) cases as well. All black cases are so early 90's looking.:p
I'll toss my request in for the blue, but if it's the right shade of red that would be kinda' hot too.
Any pics of the top of the case? I'm concerned about interference with the headphone jack -- like on my verizon silicone case right now.
Just ordered the combo kits for my phone/wife's phone. Anyone here know from past experience with innocase how well something like the tetrax car mount metal disc will stick using their included 3M adhesive?
I currently have the verizon hard red case, and it doesn't stick well to that at all. I figure I will make the disc work with the innocase somehow, but if someone knows the 3m sticky tape will stick well to the innocase material (based on experience, not guessing) or can suggest a good alternative (some type of superglue or something?) it would be much appreciated.
Thanks in advance!
Thanks in advance!
On my Tetrax setup I am using the VZW Gel case. It sticks no problem, However I am concerned about it sticking to the Innocase II.
Does anyone know if the holster clip, the one that clips it to the belt, is removable? I am asking because I would love to use the holster to protect the front of the phone, but I am a pocket person for my phone. I don't want it attached to my belt.
Thanks!!!
Thanks!!!
I've had 2 holster/case combos from Seidio (BB 8830 and Storm), and neither have had the ability to detach the clip from the holster. I am sure a quick "live chat" with the good folks at Seidio would be get your answer. They seem to be pretty knowledgeable and friendly.
hal1 said:
SEIDIO,
Hello,
Unfortunately, since we do not have a Skin Case to test out, we cannot guarantee compatibility.
Thanks!!!
It is not removable without taking the holster apart! These things are built to last :)
im debating now black or the blue like both but cant decide at moment. Though everything i have is black my insulin pump is a grey/black color so black is looking good and with the red around the camera the grey just doesn't look right imo
Hello,
Thanks seidioseidio,
I appreciate the construciton of it. Guess I will just pass on it though, because I don't want one hooked to my belt. If you guys ever make one without the belt clip - let us know!!!
Thanks!!
What would be the point of a holster that doesnt go on your belt?
Wouldn't that just be the point of the case?
There are a few reports of the camera pushing through and cracking the glass on short falls. Will this case keep protect that from happening? Is this case hard or silicone?
