Accessories Seido Surface
psoulos
I see the status on the Seido website was changed to now shipping for the Surface case. Can someone post impressions if they received theirs?
actually only the black is shipping. every other color is still 8/23.
seeing as how slow they are, I wonder when we'll actually see the active line even preorder.
Im interested in this or the active case and if either will fit the phone when using an extended life battery. Im also waiting to see what Seido comes up with for a case to handle their 3500 mah battery.
Edit: Just saw that the Active cases will not work with the 3500mah battery. It only shows this on the Combo page when buying the case and holster together. Im assuming its due to the case mostly. Dont see the same shown on the combo page for the Surface, but im sure an email to Seido might help clear things up.
http://www.seidioonline.com/product-p/bd2-hlcsr6mtdx-bk.htm
Ive ordered and $8 cheapy case off of Ebay and will continue to use my Verizon leather pouch in the meantime.
Patience isnt easy to come by for us early adopters...
i received mine yesterday. i got the surface combo, so far i'm liking the case. it's a tad bit thicker the rocketfish case, the tabs on the case is way more sturdy then the rocketfish. the volume & camera buttons are a tad bit harder to push down cause of the case thickness (i compare it to the verizon silicone case w/ the buttons tabs cut out).
the rocketfish case does fit in the holster w/ a little play to it but secure enough that it won't fall out. i'll post pics later today for you guys.
I see that is the same style as the Rocketfish cases ( two pieces, front and back), I dont really care for that style...Is it snug on there ? because the Rocketfish one feels like you can pop it off while taking pictures
That case looks pretty damn good. I can't wait to receive mine, and if that case fits with the extended battery... then I'm in heaven. :p
its a lot more sturdier then the rocketfish case by far. tho like i said this case is thicker.
btw; i just received my extended battery & the seidio case fits!! its a little snug on the left side of the phone (hdmi/charger side) but enough to close it. i just tried the rocketfish case again & it fits.
When you say thicker, I know that the Rocketfish case is rather thin, but how do you compare this? Like what are the measurements I guess? Or..... is it thick enough that I'm going to feel like it makes the phone extremely bulky?
tried to do a side by side. i don't know the exact measurements. sorry for the crappy lighting.
Seidio (left) - Rocketfish (right)
also pending which side you put on first is where a barley noticeable gap will be. you really cant see it but its there.
So essentially they're the same case, but Seidio added more protection and thickness to the middle of it. Does the Seidio make it feel bulky in any way compared to the Rocketfish?
The Rocketfish case is sturdy, it won't pop off while taking pictures.
Extended battery and its cover fit with the seidio case! The case fits on just fine, well maybe takes a little more squeezing to snap it on, but it works!!!!! With the regular battery, the cover actually has some give(room under the cover) when you press in the center of the back. Cant post pics, but trust me, it fits fine.
Your talking about the Verizon Extended Battery correct?
Are you guys serious about rocketfish? I had it for over a week and couldn't wait until i returned it back to BB. The bottom lock popped open on the second day and I couldn't close it back. For $25 its way overpriced and you can get a similar one from ebay for $5 (I got that one too, made out of different material but its the same 2-piece crap). Luxmo/Amzer TPU soft gel argyle one piece case is the best ;)
I looked at the Rocketfish model at BB today and passed. The seidio looks pretty good but I'm really looking forward to the Otterbox case which I'm guessing should be out fairly soon. I may have to get the Seidio to get me by.
