Is there a way to send information [a file] from the HTML viewer.
I had Active Notes on my old E72 Nokia.
I have copied the folder from the E72, but when I try to view notes within the programme the only way I can, is using HTML viewer. The only way I can see to send that file then, is via email.
I really need to be able to send via text, my files within Active Notes.
Is there any other viewer on Android for example?
